Rear end damage repair or swap
I took my truck in for rearend noise and they told me the spider gears are toast and the case is scorched, They won't replace it under warranty because they say they were damaged from spinning the tires. So my question is do I find replacement parts or change the gears to another ratio? and which way will be cheaper?
I blew out four 8.8's. I would swap the whole thing. I bought my 9.75 posi with discs from a junkyard for $1250. It costs over a thousand to rebuild one with the carrier and the ring and pinion. Not to mention fifteen bucks a quart times three for Ford's synthetic gear oil. It was a breeze to swap. I had to replace the right axle that was bent but that was easy too and allowed me to change the fluid while I had it apart. One of my 8.8's had an Eaton posi and Yukon gears and that still didn't hold. Good luck.
