VibrationI
Vibration Issue
I bought my 2001 f150 supercrew 4x4 3 weeks ago and i have the same issue when you turn right or left from a stop that it vibrates for a short time about a second or so. I've been a mechanic gor 13 years and have not experienced this problem, I think it might be limited slip clutch pack, because i have experienced driveshaft problems and it doesn.t mach this criteria. Thanks Howie
I am experiencing similar vibrations turning from a stop. i rode w/ a technician from the dealership, he said it was most likely the limited slip differential. he recommended a fluid flush with an additive to see if that takes care of wear. if that doesn't work, then he said it needs a rebuild.
