10.25 rear axle
Depends what truck its in. If its a 97/98 F250LD or 99+ F150 7700lb then IMO no its not a real great axle. Those 2 trucks are the same, just different badges. The problem with those is that they use 7 lug axles which limits you on aftermarket stuff. Now if its an older F250/350 with the 10.25 then its a better axle as its an 8 lug pattern. There were 2 configurations in those 10.25s a full floater and a semi floater. The full floater is the better as its a heavier duty axle.
the truck is a 2002 f150 4x4 with a 5.4L the gvw is 6900lbs
its a 5 lug rear end 12 bolt diff cover. how do i tell if its a floater?
and as i said the axel code is 27 and according to a link i found on another thread said that code means its a 10.25 axle
The easiest way to tell if an axle is a full floater is to look at the hubs. If the hub is connected to the studs/rotor directly, it's semi-floating. If the hub protrudes from the wheel a bit, and has bolts on the end of the actual hub, it's a full floater.
A semi-floating axle supports the torque of the engine, along with the weight of the vehicle. A full floating supports the torque of the engine only, while the hub/rotor assembly supports the weight of the vehicle.
-Flea
-Flea
