Taller tires on rear than front?
Originally posted by 01 XLT Sport
I could be wrong on this one, but I would think it would be a drawback. Reason being if the wheels in the back are taller it will shift the weight of the truck towards the front.
The drawback of that is less weight in the back, thus less traction.
Originally posted by grinomyte
Actually i think this would increase traction at launch since your shifting the entire weigh of the truck and sorta pushing into the rear wheel. Kinda had to explain without a model in front me.
What you say is true, the weight will shift towards the back at launch, but the question I would have is if the height is equal (no taller tires on the back) wouldn't you actually have more weight shifted towards the back for better traction?
hey man no expert here either, not trying to down play your idea, im just throwing assumptions too.
He should as the L boys.
So by all means continue my learning experience...
I would think the weight shift would be small, especially when compared to the weight shift at WOT to the rear wheels. I have heard the larger tires will give you better traction at the line
I'm not sure what happens to the areodynamics at 75 mph? That look was popular back in the days of muscle cars and bell bottom jeans.
Taller tire = more sidewall
More sidwall = more give to harnes power to provide more grip
that is why you see the sidewalls wrinkle on the trucks that are running Slicks. If they were low pro's, the tires would be spinning, not gathering Power to place to the ground.
They also look pimp.
Some of the traction bars they use drops the rear end, and some raise the rear end or keep it the same height. If you launch and the rear end drops from the traction you are getting, the weight will X-fer to the rear of the truck and you can continue to steadily incrase the Throttle
LOL
LOL
