Ring & Pinion Changeout 3.55 to 4.10
I have a 2000 F150 XLT with K&N FIPK, Flowmaster Exhaust, Diablo Chip, Shift Kit, and now 4.10 Ring & Pinion. My Question is this, will my speedometer have to be recalibrated? I stayed with the stock size tires (255-70R16). I've been told that the speedometer reads off the tires, and as long as I don"t change the tire size there is no need for recalibration. Any feedback or advice will be greatly appreciated. Thank you very much.
So does that mean in my 97 if I go from 3.55 and 33's to 4.56's and 35's I won't have to get the VSS from Superlift to correct my speedometer and shift points etc? The VSS is supsoe to control shift points speedo and even air fuel from what I understand of how it works which is why Superlift makes the VSS to reissue teh proper signal to the PCM?
Richard
Richard
