front wheel bearings 4x4
No, the only time you touch the CV is to push the splined shaft out of the hub. Thats the only time that you touch it. Just remember when you do that, that you should be pulling the hub assembly off the truck at the same time so that you don't compress or over extend that CV joint. The CV just has a flange that is bolted to the back of the hub assembly, take off those 3 bolts and the 2 should be separated.
