99 4x4 v-6 front end noise
Where do I start, about 200 miles I noticed a slight sweaking noise coming from the left front end region when going over any bump. The noise kept getting worse(louder) until I deicded to Lub (spray)all the bushings. No Help It sounded like it was coming from the shock so I chamged them no help. I can duplicate the noise by lifting the body at the wheel well. Noow the Second part while trying to figure out where this noise is coming from a Find that my left front axle is can be moved by hand at the front differantal could some how the outer cdv joint by sweaking from this. If thr problem is the front drive train do you think I have any recours with the dealer 43,000 mi. No play in the front wheel off the ground Thanks
