Eaton posi unit???
Hello Buckeye Rich,
Yes they do, see below. You could get one installed for about $650-$700, the Ford limited slip (which is not nearly as good) would run you around $900-$1000 if you have a dealer install it.
(Ford 9.75 Part #)
ED-19627-010
http://www.eatonposi.com/prod8.htm
(Ford 9.75 Part #)
ED-19627-010
Have you thought of picking up a Ford trak-lok at the junkyard and working up the clutches? I have seen several guys do this and you'd swear they have a locker. I personally think that the factory unit is a good deal. If you buy it new when you buy your truck it's around $250. At least it was in 99. Anyway, good luck and don't count out the junkyard for some good stuff cheap!
Rich
Rich
