Gear change
Gear change
I am considering a gear change in my 03 Screw 4x4. I am planning to go 4.56 ( I have 35s) with a eaton Elocker in the front and keeping the LS in the rear. Would this be a god set up? Or maybe 4.10s. My truck is 3.73 right now and I just want it to get to the stock config. Any comments would be helpful.
Ooops,
I have 3.55 gears not 3.73. it is an 8.8, probably helps to acually look at the tag instead of assuming. Anyway, maybe the 4.10 will be a better choice. Thanks for the assist. As far as the Elocker goes, it is the only selective locker I can find for my truck, and the guy at eaton said it won't be available until summer. Is this true? Are there other selectives out there for the front of my truck?
Thanks.
Jhayner
Thanks.
Jhayner
I was hoping the Eaton was available, but I don't think it probably is. The once place I can find that sells it says it is out of Stock. I've heard a lot about the ELocker but nobody I've talked to has seen one or installed one. Truckperformance.com has a real good price on them though when they do come out. I'm pretty sure they were suppose to be out already but they probably were delayed.
I have 315/75/16's on my truck and am wanting to go to 4.56's as soon as I get the money together to do it. The dealership I bought the truck from put on the lift and tires and it wasn't till I went to a Ford dealer after I had already bought the truck that it only has 3.31's Hell both of the rangers I have owned had 4.10's and one of them was just a 2.3 4 cylinder!
Can not wait to get them done!
Solid looking truck! Yeah, I wouldnt suggest anything other than 4.56 for those tires. I love my truck even more now that it has its power back. I run 2100 rpm at around 70mph. Can anyone tell me if that is good or not? Thanks
p.s. your truck must really be a dog w/ 3.31. I thought mine was bad with the stock 3.55!
