How to change a u joint?
Generally speaking
They are not to bad, but there are many configurations. There are drive shafts and axles. I did my axles this weekend on my 4x4 and by far the worst part was getting them off the truck. I had major rust on the spindles but that is another story.
Some are pressed into the yokes, if yours are, then take them to a shop and have them pressed out. I did take mine in to a shop, and was able to pound in the new ones after cleaning up the yoke. There are also C clips inside each nub that need to be removed, so If you take it to a shop they will take care of that for you.
On a hardness skill of 1 to 10, I think it is between 7 (a good home mechanic) to 9 (you will need major professional help), depending on the condition of your U-J's. Some special equipment may be necessary. Mine was a 8 due to the age of the truck 178K miles on the joints.
You might like this one but it looks like someone has the luxury of having the u-joint out of the vehicle and on a bench.
I think the beer is used to wash off your hands when done.
http://www.stu-offroad.com/otherwrit...t/ujoint-1.htm
U-joint replace while shaft on vehicle !
I sure would like to know how to change a press fit U-joint on my bronco II while the axle is still in the truck. I left the one coming out of the front diff that has a little slop, because I didn't want to remove the diff to release the stubby shaft to take it out and have it removed. I can live with the slop for now, I may ask the shop if they can remove it in place when I get some time. Hope you guys are using cheap beer for the hand wash. My MGD is too good for that.
Originally posted by UrbanCowboy
When I did mine, I had the U-joint out of the vehicle but I didn't have a workbench. I had a sledge and the crub next to the truck. Oh, and I had Budweiser. I don't see why you would replace a U-joint without removing it from the vehicle unless you were on trail.
http://snlyou.jt.org/archives/00xsch...er/fritz.phtml
Im kidding just so I don't offend you...
