Posi Clutch Packs
Why do they need replacing? If it is because the clutches are chattering going around corners, just add another bottle of friction modifier.
I had chatter in my 2000 trac lok rear. I changed the fluid and added a bottle of modifier and it didn't help. Then I found out I had a leaking axle seal, so I drained it again. This time I put two bottles of friction modifier in and it fixed it. The parts guy at the dealer suggested it. I don't know if it has a deleterious effect on the film strength or lubricating properties of the 75w140 synthetic grease.
There is a TSB on this subject that says the fix is to change the clutch pack and reduce the clutch pack shims by 0.010".
Someone else posted that Walmart is selling 75w140 synthetic now and I saw some tonight in Walmart (store brand). It cost over $8/bottle which compares to the dealer charge of $13 to $15 / bottle.
? on Friction Modifier
What is the reason for adding the modifier prior to the fluid? Does it not mix correctly, if fluid added first, then modifier?
I noticed all modifiers say to add it prior to adding fluid. I wonder if this might be part of my problem. The dealer serviced my diff a few months ago, but did not add modifier. I went back, and added 7 oz. of the Trans X modifier. It has same OEM spec #as the Ford FM. No difference in rear end problems, when making a turn. also, have a loss of power and mileage since the fluid change. 75W140 was used by the dealer.
Thanks, R1968
Thanks, R1968
If it was to add modifier only, check fluid level first, remove some if necessary, add bottle of modifier, then top off with fluid.
??am I making any sense here
I probably could have gotten it done cheaper, but I do not know that much about differentials and if I took it to a shop that I had never been to before, they could have screwed me for more. Plus my dealer gave me a loaner for the three days that they had my truck and an independent place would not have done that.
on
I just added another bottle of friction modifier to my '97 when it started chattering. That was about two years ago and it's still running alright.
If it's a 9.75" rear, you'll make up new words replacing the clutch packs yourself. The guy at the dealer will probably make up new words replacing the clutch packs. I'd add a bottle of friction modifier to it before anything else.
For about $650 or less you can get a brand new Auburn limited slip differential installed. It is a far superior limited slip differential, more aggressive, and more durable than the Trac-Lock. I agree with max mitchell don't put in new clutch packs.
Rearend chatter on left turn / grinding on right turn
I added a second bottle of modifier, about 10 days ago, and now the rear end noise is getting worse. It is going to the shop in the morning. My only fear, is they say it is ok. I need to travel about 9 hours from home in a few weeks. I do not need it breaking down on me.
