new gears and a true trac
just got my truck back from body lift, gear swap and true trac install and i gotta say man what a diff.....big diff.....so far the gears are quiet as stock and no noise from the true trac. anyone know how long of a break period is good for the new gears? my mechanic said 500 miles...could this be true or is he just coverin his ****? i'm itchin to get out there but i dont want to find metal chuncks the next time i change fluid. thanks guys.
There's a professional installers recommendations on break-in here:
www.ring-pinion.com/tech/techind.html
thanks
thanks for help guys....i'll try to take it easy. I would def recommend the true trac, it is awesome.....I took it "crawling" through some muck, 5-10 mhp, and never locked it in once and there was no slipage from the tires. I know its a LS but dam it works almost like a locker.
tru trac
still runnin like a top........even after a small diff leak went undetected which made the gears....you guessed it.....whine like you wouldnt believe and had to get em replaced again.....well worth the money and i would recommend to anyone who drives on the street alot......ive had no problems around corners or with backlash at all.
