gear question
You'll be running much higher rpms and your highway mileage will stink. Plug your numbers in here and see the rpms.
http://www.ring-pinion.com/calculato...latorsind.html
lol so gas millage will go down the drain worse then it allready is, and it will look like the 5.4 actually has some power. I tried it once with my lift installed and stock tires, and I couldn't even break thoes lose doing a brake stand. My rear end would just go about an extra 2ft up in the air thats about it.
