'98 F250 axle ident
'98 F250 axle ident
Can anyone confirm which rear end? I have a 1998 F250 regular duty (like F150 heavy).
The markings on the tags says:
3 S-114G*
3 73 10 2 8D16
I know it's 3.73 gears, & it's a 12 bolt ring gear, but I'm not sure which model axle it is.
Pix @
http://imagehost.biz/ims/album_folde...5K1B&f_id=4000
Thanks. -Ed
3 S-114G*
3 73 10 2 8D16
Pix @
Thanks. -Ed
Hey guys
The rear diff is Ford 10.25, the 10.5 is used in the superdutys. The 10.25 is very similar to the 9.75, but has a different axle spline count and of course a slightly larger ring gear. Yours is also an open differential(no limited slip).
The frt diff is just like powerstroke73 says, its a reverse rotation 8.8 and the F-150 and light duty 250 use the same one.
Cya
Cya
