draining fluids, help
ok, i am gonna drain fluids. i am kinda new to this so dont hate............too much.
i have a 2001 F150 4x4 with the off road package. i wanted to change the differential, transmission, transfercase, and steering fluids.
My quiestions are what fluids do i put in these areas, how much do i put in, and roughly what price is it a bottle?
Thanx in advance.
Thanx in advance.
I would suggest you go to your local auto part store and purchase a maintenance manual. I got mine for Hoss (97 F150 4x4 OffRoad) for $16. I have found it to be a valuable tool in my garage. They are pertty comprehensive and should be able to answer most basic questions. Go get one, I know it will help.
Good Luck!
Good Luck!
Originally posted by piperc
you should never have to replace the power steering fluid, and almost never replace the diff
If you submerge your differential under water you need to change it ASAP! Milky oil and gears dont get along very well!
Oh,and I flush the brake fluid every 20k miles or every 2 years!
Even though synthetic rear end lube has extended drain intervals, it does degenerate and become dirty from wear.
