Rear End Identification
Since yall are on the subject. I have checked mine and it says 18 on it. So I figure that means I have a 3.08 w/o limited slip. The problem is I have a 1998 4.6 4X2 and I just upgraded tire sizes from 235/70 16 to 245/75 16. Somone tell me if I am wrong on this...This means I now have an effective gear ratio of something like 2.93. My truck can't hardly move uphill.
What is the best ratio to move to, and whay type of rear-end do I have so that I may order parts.
THanks
THanks
THanks
THanks
How, do I know if I have an 8.8 or a 9.75 rear end, as some vehicles are 98 f-150 2wd and they have 9.75, and I just thought that most f-150's had the 8.8. Is there a code for that too? I have made no mods to mine, it is stock. I bought the truck used, so I don't know if the 9.75 was an option for that year?
Thanks,
Mike
Thanks,
Mike
Thanks,
Mike
Thanks,
Mike
OK,
Now that I have new tires and will be getting new gears, I am sure that I will have to calibrate my speedo. In my 98 f-150, do I have the gear that needs to be swapped, or can I do this with a tuner, dealer ECM flash...etc.
old tires: 235/70R16 Diameter: 29"
new tires: 245/75R16 Diameter: 30.5"
old gears: 3.08
new gears: 3.73
I have used many calculators and I think that I will might be able to keep trak of speed with RPM's, but this in inconvenient and not very accurate.
I have checked many threads and searched, but didn't find my specific vehicle and saw each of the options listed above for other year models.
Thanks ahead of time for any help.
Mwkatm
old gears: 3.08
new gears: 3.73
Mwkatm
Max,
Thanks for the link, looks like for my set up, no matter which drive gear I have, I just need to count the teeth on the driven gear and increase the number of teeth by 15% (at least that is what my math tells me). I do have a question though. Where do I get them, will a dealer have them, the link you sent me has part numbers for gears, however I have no clue which company's website I am on when I am there.
Again, I really appreciate all of your help, and by the way, I have installed my new 3.73 gears and I absolutely love them, its like I have a new truck. NO more sissy downshifts on tiny hills. I'll bet it even runs better when the ECM gets a better idea of how fast I am driving so it can calibrate shift points, and timing adjustments.
Thanks,
Mike
Thanks,
Mike
You're Welcome ! Yes, gears really wake a vehicle up and give it a whole new attitude. A bunch of places sell the gears. The Ford or Ford Racing pieces are quieter than some. Try here:
www.steeda.com/store/-catalog/speedometer.htm
www.redrider.us/ford_aode_parts.htm
Most Mustang parts dealers sell them. Try a general browser search for ["mustang" and "speedometer gear"] or search here for "speedometer gear" and several pages of member experiences on F-150s will pop up.
