tranfer case fluid
The fluid in the transfer case is mercon trans. fluid. The proper level should be even or just below the filler plug. If it seems to be over filled, you might check the transmission fluid level. If its low, there is a possibility the imput shaft seal in the transfer case is bad, causing trans. fluid to enter the transfer case.
