When to change Diff. Fluid
Definitely change it yourself.
You can get Royal Purple through this website -- http://www.hiperfuels.com/ -- for under $9 a quart. Use it and you won't need the additive.
As far as a torque sequence. I generally turn them all finger tight, then snug them a bit and then torque them down in a standard pattern. I. E. opposites
TIP When you look at the diff you will see several bolts that hold the pan along the bottom that are exposed on the front side. When you install these put some sealant on the threads or you'll have leaks that come down the threads to the front of the bolt. Also when you go to break the pan leave 2 bolts at the bottom just there not tight and start your break at the top and use those bolts as a sort of hinge for the cover. That way you don't get the waterfall of diff fluid when the pan pops off. make sure you have a wide deep pan to minamize splashing and open the garage door. I don't think Mama wants that smell of the fluid(sulpher) all through the house. Plus have plenty of old rags that you intend to throw away handy to clean out the sludge in the bottom of the"pumpkin". Good luck
Originally posted by RedFord150
It was recommended that if I use the Royal Purple Gear Oil I do not need the Friction Modifier.
Is there any risk in adding the Friction Modifier to be on the safe side?
Thanks again to all of you.
old school oil
I tend to change fluids more often than recomended. All this talk about synthetic is too much for me. I dont really like synthetic. My manual recomends the same 75w-140 synthetic. I use the regular old from the ground oil, not synthetic. Granted i dont have a LS diff. I have changed my fluid twice. The second time i inspected my gears to see if there were any bad affects from the standard oil. They looked just as good as when i took the cover off the first time, when it had the factory synthetic. I think i payed less than $15 for all the gear oil i needed.
What i did learn is that no matter what the guy at the auto parts store says, dont use the gasket that they sell if you have a newer truck. Mine leaked when i used the gasket. I used RTV and i have not had a problem since. I did not put it on my bolt threads or holes.
I saw that someone said that felpro gasket, i cant say if they work or not because that is not the brand i used. I just know that liquid gasket works great.
Re: old school oil
