Gearing help????
This is what I have.
5.4L 4x4 auto w/OD 35's and 4.10 gears.
With that said, if you are similar I would put 4.56's in. Especially if you go offroad. I do alot of Hwy driving but Im statring to think the 4.56s would have been a better bet for me because of the OD. Not to say the 4.10's are weak cause they are not. I have Richmond gears and I am very happy with them. Motive is a good gear too. A little cheaper and they are made by Richmond.
You can get the axle code from the driver's side door jamb sticker. This code can be posted or searched here for an actual ratio. The actual ratio is also included on the second of 2 lines of information on the axle tag, under one of your rear cover bolts. The 5.4 uses a 9.75" axle and the 98 model has a different installation kit than the newer versions. The 9.75" has no ratio between 4.10 and 4.56 like the 8.8 does. The 9.75" parts cost more as well. Yes, I recommend changing gears. If you don't have a LS, I'd install one while the differential is removed. I agree with the others on the 4.56 route. I've had good luck over the years with U.S. Gear and Precision. Changing the front and the rear gears on a 4x4 will be a hard hit on your wallet. Assuming you have a shop do it, you're looking at about $1,200-$1,400 ,plus LS cost, if you add that in.
Gears
Bigtruck311, What type of 4.88 gears do you have? I have a 98 Expy with Precision 4.11s and will be going to 4.88s soon with newer tires. I'll be going to the same PJs I have, but in 38x15.50s. So far, all I can find are Yukon gears for my 8.8"-IFS-CV front end and 9.75", 12-bolt rear end. Thanks
