Bronco Driveshaft
A little more info, please. You have a double u-joint at the front. Have you tried raising the rear tires off the ground and putting it in gear to isolate the noise? Try it in neutral, with 4x4 engaged(not with the rear off the ground) See if you can do something that changes it and then you can truly isolate the cause.
Robbie
Robbie
