Towing Question
Towing Question
Hello Gang -
I plan on towing a small popup camper with my '95 F150. It has 221,000+ miles on it. It has the 302 engine, with a 3:08 rear end (I think) and a 4r70w transmission. The loaded weight of the camper is about 1800# and a tongue weight of about 180#. Generally, I will stay within 3 hours of home, but may travel in some mountains in western NC. Under normal circumstances, is this truck set up to tow this small camper?
Thanks for your responses!
John
John
I would think any vehicle with a V8 engine should tow at least 3,500#.
Ford gets a little weird. They rate their auto trans pick-ups to tow more than the manual trans (comparably equipped), at least in recent years. The 3:08 rear-end is geared on the high side. Not the best choice for towing. Obviously, the high mileage engine should not be pushed too hard.
1,800# is nothing. The 180# of tongue weight is similar to a grown man standing on the rear bumper.
Unless your truck is in really poor condition, you should be fine.
Good luck.
Good luck.
You should be fine with that weight. I used to tow a boat and trailer that went between 2000 and 2500 lbs with a 90 F150 with 308 rear and a 351 engine. I Didn't even know it was behind me.
I would suggest that you get an aux trans cooler if you don't already have one. Even though it's not a lot of weight, it is putting more stress on the trans.
I had an 88 with the 302 and 3.08 gears and I pulled trailers all the time. You barely felt it until the load got over 2500 lbs or so. I was doing landscaping and tree work so I hauled a lot of trailer loads across the dump scales. Assuming the truck is running properly, a 1500 lb trailer should be like nothing.
