U-Joints,How to Check ?
Chock the wheels
set the e-brake
put tranny in neutral
crawl underneath your truck
grab the drive shaft
slowly turn the drive shaft (back and forth in both directions), paying very careful attention to the u-joint. There should be no slack in the u-joint. If it is really bad, you can hear it clucking when you change rotational direction on the drive shaft.
4wd
chock wheels
set e-brake
Front Hubs un-locked - transfer case in 2wd or neutral
do the same thing as above with front drive shaft
I think I got it all. Should be the same for auto trannies too.
set the e-brake
4wd
chock wheels
set e-brake
