Ford's fix on the rear end whine???
For me, the only cure for the rear axle whine on my '01 Screw with 3.55LS was replacement of the entire rear axle assembly - housing, gears, bearings, everything. My local dealer (who I must give props to for being very cooperative through the whole process) rebuilt the diff twice under warranty, with little success at stopping the whine. Finally, after consulting with the regional reps and FoMoCo engineering, they replaced the entire assembly, (at 35,800 miles), and there has been no whine since (currently at 93,000 miles). I think the conclusion was that some axle housings had/have slight casting flaws such that the gears can never be set up exactly right, and thus the seemingly unfixable whine.
Try pushing for replacement of the entire assembly.
SM
SM
I’ve decided to replace ring & pinion all bearings seals etc.
Differential Rebuild Kit, $68.65...
Differential R H Bearing, LM603049-LM603012
Differential L H Bearing, LM603049-LM603012
Pinion Front Bearing, M88048-M88010
Pinion Rear Bearing, M802048-M802011
Pinion Seal, 3604 (18190)
Brush, BR1
Gear Marking Compound, GMC1
Thread locker 242, Til
Pinion Nut, PN2
Crush Sleeve, CS311
Sealer, RTV Silicone
Pinion Shim, SK4
Carrier Shim, SK7
Ring Gear Bolt, RGB3 (10)
Ring & Pinion Gears, $133.65
Brush, BR1
Pinion Nut, PN2
Crush Sleeve, CS311
Pinion Shim, SK4
Carrier Shim, SK7
