Lower gears w/ 35" tires
Got a few questions. I know alot of them are addressed elsewhere but I have noticed that alot of guys have the identical truck w/ the same tires, so I want to hear it from the guys who know.
I have a '02 F150 Supercrew, 5.4L engine, exhaust, intake, 3.55 gears, and 35" tires.
It is slow now so I want to get some power back, so:
1) What gears should I get to go back to stock configuration?
2) I lost gas mileage when I got bigger tires, is it going to be alot worse than it is now if I go with lower gears?
3) How much is it going to cost? Average.
Thanks alot,
Matt
Thanks alot,
Matt
genuin gear yukon are the two brands i have used in my vehicles, if you have never done gears in a rear end i would find a freind that has to help you(one you trust) you will also need some speceal tools not every shade tree mech has, bearing press dail indocater and a backlash indicator, it is a very time consuming job that requirs lots of patience, you might have to pull the diff out a couple of times to get baclash and shim depth correct, good luck
