1996 Hub Removal help
Guys I need some help. I am replacing the front rotor on my 96 F-150.
I have gotten the outer axle nut off. Now is my problem. Behind the nut is a washer with holes all the way around it. On the inside diameter is a tab that goes in a slot on the threads where the axle nut threads onto. There appears to be a pin in one of the top holes. The washer is loose but appears to be held in place by a combination of the tab and pin. Does anyone know how to remove these?
Make a hook tool out of a stiff piecee of wire pull the washer off there is a second nut behind it with a pin sticking out to enguage with one of the holes. during reinstalation tighten back nut then adjust it back and forth to get the pin to go into hole then tighten outer nut, be carefull not to over tighten the outer nut or you can brake the key and the washer will turn causing major problems.
