Busted Axle Seal
You have to remove the rear end cover, draining the fluid. then remove the pin that holds the gears in place, push in the axle enough to remove the c-clip and pull the axle out. With the axle out, you can pop out the seal with a screw driver. I use a piece of 2x4 to drive the new seal back in with a paper towel or something covering the seal to prevent dirt getting in the axle housing.
-Joe
