Need Info on 8.8 rear ends
Wanting to convert to LS.
Will a Differential Case from a 2001 f-150 Tag# S829D interchange with
a 1995 f-150 Tag# S832J or a 1988 e-150 Tag# S724S banjo?
How many splines on the 2001 f-150 Tag# S829D axle? (28 or 31)
Do all 8.8 ring gears have the same bolt pattern to the Differential Case?
Will be using the old ring and pinion, just wanting to change the
Differential Case to LS.
Thanks in advance.
Thanks in advance.
http://www.pirate4x4.com/tech/billav...on%20chart.pdf
Pirate 4x4 has the Auburn application guide which lists years and spline counts
Jack
Jack
Now that I am done with the job I will answer my own questions.
a 1995 f-150 Tag# S832J or a 1988 e-150 Tag# S724S banjo?YES
How many splines on the 2001 f-150 Tag# S829D axle? (28 or 31) All F150
with an 8.8 have 31 splines
Do all 8.8 ring gears have the same bolt pattern to the Differential Case?YES
Thanks for the reply
