Worn Ring and Pinion Gear on 2003
Help - 2003 F150 going back to shop for the 6th time:
#1 - Replaced Bearing - 3000 miles
#2 - Replaced Ring/Pinion
#3 - Needed to order parts
#4 - Replaced Bearing/ parts
#5 - Found Ring Pinion Gear worn - Replaced
#6 - Stills wines - But louder and now has viberation
Dumb question - when did you buy this, and from where?
If you have purchased it in the last 18 months, I believe that your vehicle could technically be considered a lemon, because normally the definition of such is a vehicle that has been to the shop at least 3 times within an 18-month period for the same issue. If it has, then you have grounds to demand some sort of restitution w/r/t the Lemon Law. However, I'd make sure that is the case in your state.
