another gear question
i have a 2000 f150 2wd/v6/5spd. i am planing on installing a 3 inch suspension lift, a 3 inch body lift, and 35's. also a k&n air filter, flowmater SI/DO exhaust, and a chip. my question is are 4.30:1 gears going to be ok or do i have to go with 4.10:1 gears. during the winter i tow a trailer with two 600# atv's every weekend and a 16' fiberglass bass boat on ocasion during the summer.
I think with the 4.2 he has the 8.8 rear end. If it was me i'd get 4.56's, 4.10 if you do alot of highway driving. I had the same truck as you except I had the auto and I put 4.10 in it. I had a 3 1/2 inch suspension lift and only 265/75/16 tires and the 4.10 were perfect. On the interstate at 70 it was only turning about 2200 rpm's. It's up to you but I'd would get 4.56's.
456???
dodge_slayer01
I just saw your last post, and my guess is that 35"ers and 456's would be a good combo with good low end and decent freeway rpm's..... and put you near my 410 / 30 1/2" which tachs about 300 - 400 rpm higher at 65 - 70 .............
Best to do more homework and use the advanced search feature here....... I'm sure it's been done and posted.................
