93 F150 broken transfer shift lever
Broke the transfer case shift lever. It's OK since it's only a yard truck used for plowing, but i'd like to get it into hi range fwd. I can push the lever underneath the truck, but it'll only go into 2 wheel, neutral, or 4 low range. Suspect i need vacuum to make the shift into 2 wheel high. How do i do thid with a broken lever?
Thanks, John
Thanks, John
