posi or Ls or Locked
Indeed, Posi-Trac is the GM patented name for their limited slip diff. Ford's brand-name for their limited-slips is the Trac-Lock differential. Trac-Loc and Posi-trac are TYPES of limited slip differentials. There is also the Torsen (gear-type), Detroit Locker, Auburn, and Tru-Trac, or Lock Rite just to name a few. (The latter are lockers, but in my book, they're the only ones that truly limit the amount of slip.)
-Joe
-Joe
Originally Posted by DiPalo
How hard is it to change out the gearing. I know the 8.8 in the older Mustangs needed to be shimmed and the 9" in my 66 coupe is easier. BTW what size rear is in the trucks. 05 screw 5.4. I have the 3.55 now. Any suggestions to go with either a 3.73 or 4.11.
Everyone seems to agree that the jump to 3.73 from 3.55 is not enough to be worth doing.
They are probably right. I will eventually switch my 3.55 to 4.10 when I get nearer out of warranty.
I don't know how hard it is to do on the 9.75, but suspect with the rigid frame, and various problems with the shaft and LS that you would be better off having it done somewhere that you get a warranty.
Just a friendly suggestion.
