Axle swaps?
Your a lucky guy, because you have a 250 LD, you have a 10.25 rear axle. One of the toughest most heavy-duty rear axles you can get on any half-ton truck. I would rather have that than more wheel choices, take your wheels in and get them chromed. You also have a heavy-duty frame, bigger brakes, stiffer torsion bars and taller gears, all of which are good things, just my 2 cents.
Thank you,, I have 99' F250LD that I ordered from factory, picked the rims (chrome) and each feature. And I don't hear many good comments on the forum. I've had it 6.5 years and still love it. 40k I kind of like looking at other trucks looking for the 7-lug. But it's good we all don't like the same things.........
Thanks, I feel better about the 7 lug now. I didn't know it was more heavy duty. Some people told me it was just like a 150.
The frame,brakes, torsion bars,are really more heavy duty?? Thats great.
So its not like an expedition, like i was told also.
I have 3:73 gears, LS, 5.4 , and I really like the truck. I was just deciding if I was going to invest in a lift and tires and all that.
If I go to a 17" wheel I do have more choices of rims. My rims are chrome and in good shape, 16x7, and they are steel which are stronger also.
Thanks guys.
Thanks guys.
Thanks guys.
Thanks guys.
This is not to confuse it with the vast majority of F150 new model that have the new 6 lug rims, and 9.75 or 8.8 rear ends.
My thought was if the seven lug on the 10.25 was the same as your you could nab the factory rims, slightly upscale from the F250.
Again, just a thought.
Chris
Originally Posted by rkjerue
The new model F-150 with 7-lug wheels and 10.25 axle is the same as the 97-03 moldes the wheels should fit.
The new F-150 is a 6-lug pattern, not a 7-lug.
Is it possible to swap the axles? Sure. But I wouldn't want to.... the Sterling axle is much stronger than either of your other bolt-on choices. (i.e. the 8.8 or 9.75)
You could probably have a set of custom axle shafts made (for a pretty penny) and swap out the front hubs for a 5-lug, but if you went through all that trouble, why not just get a light-duty F-150? It'd be cheaper, for sure....
Just don;t see the logic in it myself.
-Joe
Originally Posted by GIJoeCam
Umm, wrong.
(Heavy Duty Payload Package- 2x4 model Per Ford Website)
- 50 Emissions System
- 4.10 Non-Limited Slip Axle Ratio
- 17" 7-lug Steel Wheels
- 8200 lbs GVWR
- LT245/70x17D BSW All-Terrain (5)-(General)
- 3060 lbs Maximum Payload
- Heavy Duty Shock Absorbers, Frame and 72 Amp Battery
- Upgrade Springs, Radiator, and Auxiliary Transmission Oil Cooler
- 10.25" Gear Set with 4.10 Axle
