drive shaft vibes
Originally Posted by kingfish51
Can't say I have heard that. If I had a vibration on my drive shaft, the first thing I would check/replace is the U-joints.
Originally Posted by bobfawcett
I had a 98 Ram with the same problem.The solution was a shim on the leaf spring under the axle to change the pinion angle which should have come with the lift kit but mine were missing I guess.Maybe your angle is off too.Something to look into.
Bob
Bob
