Loud noise in differental
Well let me say first that I am talking about a 1996 Ford Bronco 4x4 (there is no form for broncos) Well my problem is when I step on the gas there is like a loud roaring noise from the rear end and when I let off it stops, it only does it when there is torque on the rear end. A shop said that it is a gear in the diff but I can't remeber the name but it started with a "P". If anyone knows what it is and how to fix it please write back. Please! Or even if you know what it is.
I would of guessed the same, the pinion gear is making noise with the ring gear. One way of checking is to take off the back cover and see inside, seeing the wear pattern if something else doesn't tell the story. Sounds familiar though when they don't mesh right, they have a tendancy to whine even, under load.
