4.56 at the very least. You could go with 4.88's if they're available to make up for the extra weight of the 35" tires, especially if you do a lot of off-roading or towing.
4.56's would put you back near stock. I would go with the 4.88's. I used that same combo on my 1993 F-150, 35's and 4.88's, worked great. Hope this helps.
4.56 would put you the closest to you origanal drive ratio, you you wanted alittle more grunt i would go with 4.88 this would only put you around 150 rpm or so higher than what your original drive ratio was, good luck
