Limited Slip Shudder Fixed!!!
Hi - Some time ago ,I posted that I had shudder in the drivetrain when I first started and when I turned. I finally determined that the clutch packs in the limited slip rear axle were causing the problem. I tried the Ford friction modifier along with changing to 140W lubricant ,but it did not make a difference. Then I saw a post from a mechanic member who recommended RedLine lubricant 140w with the friction modifer and it worked!!! When I first changed ,the difference was minimal ,but within 30 days the shudder was gone!! Even Redline's website mentions that this type is used to correct rear axle problems in late model Ford trucks. Thanks to the member who posted that tip!!
