Posis and lockers
Posis and lockers
I've got a 1999 ford f150 lariat 2wd. It came with a posi in the rear, but i was wondering if it would make that big of a differnece to put a locker back there too? Or if i should lock the front up. Also im putting a 2 inch level in the front so im thinking about putting bfgoodrich AT on. Does anybody know if its worth the money to put a locker on it?
Well being since it's 2WD you can't lock up the front.
The way I've always looked at it is if it's 2wd put a decent LS back there and call it good. I know some may disagree with me but putting a locker in a 2wd is waste of time and money to me.
If you're happy with the performance of the factory ls now then I wouldn't worry about it. If it's not pulling both tires quite like you want it to, an aftermarket LS will mostly likely cure that.
