Cracked Driveshaft Knuckle
Hey guys - originally posted this under the transmission folder but thought this might get a better response here, so sorry for the double post. I've been hearing a clicking sound the past few days when taking off from a stop and finally got a chance to dig in tonight. I thought possibly I had lost some fluid and it was the sound of my transmission, but fluid level checked good. I crawled around underneath and somehow happened across what must be causing the noise. It seems that my rear drive shaft has cracked at the knuckle just forward of my differential. The crack is at the attach point, and part of the attach is missing, so basically instead of the knuckle locking onto the differential at two points, mine is only locking at 1 1/2. The noise I've been hearing appears to be the bushing/sleeve around the lug moving around and it looks to be coming apart as well. Obviously I won't be pulling anything until I get it fixed and will definitely be trying to get it fixed ASAP. The question is - how bad am I looking? Can I disconnect both ends and get it out and a new one back in without dropping my rear end and what's the best source for a new shaft? I thing a repair is completely out of the question - I pull about 4000lb boat and the occasional grain wagon, etc, so it does get used and I have no desire to risk a weld job. Any input is appreciated. Thanks guys!
