98 Expy can't get axle c-clip out
Old 10-07-2006 | 10:11 PM
Mudman78's Avatar
I got the left rear axle out, but the right rear axle won't go in far enough to remove the c-clip. You can feel it bottom out when you push it in, but there's not enough of a gap to remove the clip. It's a limited slip. Do I have to compress the clutch pack somehow? and if so, is there a special tool?
Old 10-07-2006 | 10:39 PM
Quintin's Avatar
The wheel studs on the axle flange are hitting the parking brake anchor. Turn the axle a little further so the studs clear the parking brake anchor, the clips should fall right out.
Old 10-08-2006 | 05:38 AM
Mudman78's Avatar
Thank you, worked like a charm. I feel like a tool that I couldn't figure that out on my own. I was laying under the truck keeping the clip from falling and was reaching around the axle with my other hand pushing the axle in. I never saw it.
Thanks again.
Old 10-08-2006 | 02:18 PM
Quintin's Avatar
Thanks again.
Don't mention it. It took me a few times to realize the same, and I do this stuff for a living...:o
Old 01-06-2007 | 01:33 PM
Aycardus's Avatar
I was just having the same problem and this post came up through search.
Thanks a million! I feel like an tool as well, heh!
