Overdrive fuse
Overdrive fuse
Pulled a load with my 2000 f150 4x4 this weekend with the overdrive off, all was well. Tried to cut it off again today and it blew the fuse and would not go off. I put in a 5amp mini fuse it worked at first and blew again. I tried a 10amp (all i had) and it worked fine. Tried it again once I got the truck up to speed and it blew that fuse. Were do I start the search.......
on
Originally Posted by debter
hello, where do I find the mini fuse for 1997 F150? pls hlp
Fuse F29 in the under-dash fusebox.
Download an owner's mamual from www.fleet.ford.com under MAINTENANCE or pull the one out of your glovebox.
Steve
Steve
Steve
