Noise in rear end when turning tight radius
Hey all,
I'm new to this forum and would appreciate any help you could give. I have a '03 F-150 Flareside with 3.55 gears and a limitied slip. I just started getting a low pitch sqeaking sound when turning tight radius turns like parking spots, etc. It is somewhere between a rubber on rubber sound and a low metalic grind. I jacked up the rear end and there doesn't seem to be anything obvious. There also doesn't seem to be much play in the axle itself but there a little bit of play (maybe 1/8th in.). I'm not very experienced mechanically speaking. Does anyone have any ideas. Will this be expensive? I did get the extended warrantee when I bought it so I am still covered. Oh, it has 63K on it.
Thanks,
Dale
Thanks,
Dale
