Breaking in new gears?
The tech told me my ring and pinion were ok.He also said my pinion bearings were ok too.They replaced the spider gears,pinion shaft and bolt,c-clips,axle bearings and seals,along with the u-joints.Do I still have to break the spiders in the same way?Why would spider gears go bad?I thought they were only used on turns,and I "do not" hot rod my truck in any way! I don't even haul anything!
Originally Posted by frobird
You probably didn't need your spider gears replaced. The old spider gears would have worked in the new carrier, so it was just another excuse to make the bill a little bit bigger Also, you didn't need the pinion shaft, bolt or c-clips replaced. All of those parts are meant to last a life-time, unless you end up snapping one, which is really hard to do anyway. I'd recommend you not take your truck back to wherever you got your gears changed out, they really ripped you off.
The part that baffled me is,how did they know my pinion bearings were ok if they did not take the carrier and such apart?
Originally Posted by bigtruck311
i always recomend to take it easy for the first 500 miles then take the cover off and check for abnormal wear and change the fluid. good luck.
Those are the only parts they replaced.They compared my spider gears with new ones.Mine were chipped,rounded on some edges,incorrect wear pattern,and cut grooves in some of the teeth.The spider gears came in a kit,which included the pinion shaft,bolt,and c-clips.
Good news about the spider gears though. Glad to hear you weren't ripped off By the way, how much did they charge for the installation?
