97-03 locking hubs?
97-03 locking hubs?
i've done a few searches which turned up nothing.
Has anyone heard of or seen locking hubs for the 97-03 IFS? i would love to have something like warn manual hubs so i can lock in 1 wheel on the icy roads. i have a locked up front end and it is flat scary when it decides what wheel has more traction.
I have driven quite a few miles with a 98 and an 01, and never had a problem. Same with manual lock hubs and having both locked up. Not sure why you would be having a problem.
Also it is unlikely any one would make a hub for a vehicle that wasn't designed for one.
This is Christmas, not April fools day. Sorry I couldn't resist. You must have had a bad experience to have that notion. On an older front differential with lockout hubs if you locked just one hub in, you would get no benefit from the front(4 wheel) drive. If there was some kind of special locker differential that worked with just one wheel locked in, I could only see that making the truck handle worse.(when just one side was locked in) Do you have badly worn tires or badly mismatched tires such as good gripping tread on one side and smooth tread on the other side?
what did i miss here with my theory?
Originally Posted by Klitch
you had the front end locked up and you did not have any problems?
Edit: by lock i mean like an actual locker of some type. i have a richmond gear mechanical limited slip / lock right.
Never put a full locker on the front.
i was told that the richmond gear's lock right would ratchet and act like a limited slip.
now im not sure if mine has issues again, had issues with install. but i was looking for a round about way to remedy this
http://www.powertrax.com/lockright.html
kingfish: i know people who run yota's with a full lock in front and one hub disengaged.
my front end is locked up, thus adding hubs and leaving one free and locking one would make it run like a OPEN front end bud. an open front end spins one tire when you have traction.
You have clearly modified the truck without knowing how the original system worked to begin with.
IMHO, for an on-road vehicle, the lock rite was a poor choice for your F-150 to start with. Sure, it was relatively cheap and easy to install, but it will cause exactly the handling problems you described. It's the nature of the beast. You have an IFS, with relatively weak halfshafts. Yes, the wheel that needs to turn further will ratchet and be allowed to overrun the inside wheel in a turn, but it will still easily shock-load the front halfshafts when it reengages, snapping them easily.
Furthermore, the Lock-Rite is prone to not acting like an open diff when not being driven. In 2wd, the center axle disconnect breaks your passenger side axle shaft near the diff, simulating a broken axle shaft condition. That can cause a lunchbox locker to force the front driveshaft to spin at all times, being driven sloely by the front driver's side wheel, and causing a pull on pavement in 2wd. Again a poor choice for a street-driven vehicle.
PowerTrax confirms this right on their web site:
We recommend the LOCK-RIGHT for vehicles that are primarily driven in severe driving conditions or are used for recreational off-road. For vehicles that are driven daily or require more mainstream application, the POWERTRAX TRACTION SYSTEMS offer a quieter and smoother performance. Please see the POWERTRAX® TRACTION SYSTEMS page.
Good luck!
-Joe
