Axle Swap
Axle Swap
Hello! I have a duo of 01 F150's with bad rear axles. I am currently driving the same vehicle with 3.55's on it and am assuming that it has the same gear ratio. I was wondering if I could swap just the whole axle with a different gear ratio and change the speedo gear or if I am better in just replacing the gears in the rear end... any advice would be great!
Originally Posted by jizto00
What about swapping the 8.8 rear end to a 9.25? Is there any problems I might encounter. I was considering going to the bigger rear end anyways and upgrading my f150 to a heavy half ton.
Phil
FYI, I just bought a complete assembly from a junkyard, including the gear ratio I wanted, brakes, and everything for $700, which allowed me to install it by myself in about an hour. I didnt have to mess with all the labor of changing out the gears. I inspected the gears and brakes, and they were all in great shape, including the pads... all it cost me for labor was new fluid.
Quesntion
Kinda off topic but how do I know what gear ratio my truck is...i just got into a pretty bad front end collision and I am trying to rebuild my front end...but I need a front axel housing(the tube that the axle runs through) and I can not find one. I had one place come close but I needed the gear ratio. I know there are tags on the differential and transfer case but I do not know what they mean...any help
Example, 19 is a 3.55 open diff.
8.8 to 9.75
Hi, on ebay I found a new 9.75 3.73 rear axle complete with rotors, pads, and calipers. It says its for 04-up. Now being that I have 17 inch wheels will this swap into my 99 8.8? I have rear disc but i really want the 9.75. Plus mine may be on its way out with 110,000 miles. Can anyone tell me if this will work?
