Ring and Pinion
Ring and Pinion
I'm debating whether or not to regear my truck myself. I changed carriers in my rear diff a couple months ago and I'm just wondering how much more involved it is to swap gear ratios. I guess if I do it and get any noises, I can just take it to a shop and have them redo it...
Also, I've got the 8.8 and I've seen that with 4.56s I have to get a different crosspin. Why is this and is there any way to get around it?
will u need the pinion depth gauge i plan on doing my own time and 3300 mile drive shortly after though it might not me a good idea but if you tear ur axles apart like as my dad did mine saves u alot of money to have it done $900 for every thing labor master install kits for both axles i like when they dont have to take every apart
you will need a bearing press to get the old bearings off the carrier and the new ones on. you will also need a magnetic base dail indicator to measure the backlash other than that evreything else should be common tools, it is a very timely process to get the gears setup properly if you do not know what you are doing, but every one got to learn, just have patience on the set up process, use a micromiter to measure the shims on the pinion and side to use as your baseline and make adjustments from there, good luck.
Originally Posted by jiggle
Like I said I swapped carrriers a while back so I'm familer with shimming it out and the whole backlash process. I just wanted to know if there was anything else I should know about the pinion gear, as I have not messed with that before.
I have 1" drive impacts that put out like 1000ft/lbs at my work. If that won't do it I don't know what will. So far it doesn't sound like the pinion gear is really anything difficult compared to shimming the carrier. I think I'll try it myself and if I'm in over my head I'll take it to a shop and let them deal with it.
Originally Posted by bigtruck311
Duffman0286, were you at in Iraq? i am out at Haditha with 2/3 in the Anbar province. going home here shortly i hope. you take it easy and keep your head down.
Sgt Cuda U.S.M.C.
Simper Fi
Sgt Cuda U.S.M.C.
Simper Fi
Great to see other marines on here currently in TQ airbase spent 6months in fallujah and 6 here in TQ year out here is way to long.. be heading to cali next wk im a ENG with 9th comm
great truck you have there sgt one of the those trucks that force me to lift mine.
Lcpl Eliason
Lcpl Eliason
Lcpl Eliason
you have probably seen my truck on Pendleton, this is my third tour to Iraq, i did two tours with 7th eng. in the 14 area for the invasion and fallujah out at the mech. now i am attached to 2/3 out in the middle of no were. TQ is nice, chicks everywere, there are no females out here for miles unless you count hajis. i will be heading back in a month or so doing a 9 month tour. i will look for your truck on pendleton i am out in 41 area with Light Armoured Recon. you take it easy and have a safe trip back.
Sgt Cuda
Simper Fi
no i havent seen it yet only spent a wk in cali b4 i deployed
you be seeing mine in april its back home in indiana
guys, tried to keep ya'lls heads up and asses down over there. i did 13 months Army Infantry over there back in 04. our AO was between camp liberty to taji, and from there we made a triangle up to abu ghraib.
when ya come home, look me up
Sgt Cuda
Simper Fi
