Good deal on fixin the rear end whine?
Originally Posted by TRIXSNK
Was it farily obvious the carrier was warped when inspected by another mechanic? Did the others just miss that?
I got my 02 at 33,000 miles and later realized the rear sing happens between 45 and 55 mph but not very loud. Truck now has 79,000 miles, has pulled max limit gross combined weights and still has not gotten any worse.
It's interesting that a lot of trucks had this wine/sing in the same range.
I would think the carrier was not machined straight from the factory, not a warped condition.
Makes sense since nothing done will change anything using the original carrier casting if it is not machined true.
Currently I am rebuilding an 8.8LS in a car with everything but axle drive gears and carrier casting. Both truck and car rears are built the same way except for axle spline counts etc..
Good luck..
Good luck..
yup
Originally Posted by Quintin
Think about this for a second - if the axle is noisy, something's changed/broke/worn out to cause this noise. Changing pinion depth to try to fix it is like taking asprin for a chainsaw wound.
If you're gonna go so far as to disassemble the axle to gain access to the pinion gear, you may as well inspect and replace whatever else needs replacing while you're in there. No sense in half assing it, 'cause you'll just have to take it apart again later.
