what gears am I running?
Check Differential Tags
Hi
If you crawl under the truck and read the differential tags, for me it was the tag on the right as you look at it from the rear, it will tell you the ratio. Make sure to clean tag. Also the first number is stamped real close to the bolt hole so look close. If you are looking at the tag, its the bottom set of numbers if you were holding the tag level.
