rear end leaking
rear end leaking
i have noticed not only on my truck but on many others, that the rear axle on most of these trucks looks like it has a leak. i always have my axles serviced when i change my oil, so i would think if any of my axles were leaking they would let me know. perhaps it is just a build up or road grime and oils from the road that are gathering on the rearend. i have never noticed drips or oil stains on my driveway.
It's common on a LOT of trucks.
I suggest giving your differential a thorough cleaning (pressure washer, some simple green, and maybe even a scrub brush) so you can get a fresh start.
Then watch to see if it starts to get dark and wet looking again. If so, it may need to be re-sealed, or possibly have the housing "sanded" and sealed.
look at any older truck there is almost a stain on the cover from when the fluid was changed. it can stay there for years. gear oil is tough stuff. the cover could have a tiny pinhole rusted thru and is leaking. had a oil pan that did that once.usually rear end leaks at the axle seals in to the drums from what ive experienced.
Originally Posted by keith97xlt
is that seals for both wheels?? 150$ doesnt sound to bad. the seals are like 15-20$ each. 1-2 hours labor. jiffy lube and those chain places charge 80- 100$ for a differential fluid change.now thats a rip off!!
Originally Posted by 89Lariat
Lets see; $10 for gear oil, .50 worth of sealant. 5 mins to take the cover off and 5 to put it back on. Ya, $100 sounds about right
