2001 F-150 clutch pack - where to buy
i know most people like to put things back just like factory but what techs do
isnt what you think.if you drain all the ford fluid and add only the {royal purple}synthetic oil-it comes already mixed and works ALOT better for clutch
pacs.ive done thousands of overhauls from new clutches to add and refill.if
after using this product you STILL have a problem then you really need to get
an overhaul.
an overhaul.
an overhaul.
an overhaul.
Originally Posted by Kevin24
This goes for the 8.8 and 9.75 rears,it says add 4 ounces of friction modifyer part#C8AZ-19B546-A to diff,like i said i'm gonna try double.The gear lube is
SAE75W-140 GL-5 synthetic gear lube,aprox 5.7pts.These are both ford part #s.The rear diff fill plug,torque to 15-30 Ft-lbs,cover bolts are 28-38 Ft-lbs in increments,don't do it all at once and go all the wat around the dif,if you do it all at once you may warp the the cover.
also when you silicone the diff cover make sure you go around all of the bolt holes besides the original bead you makealso there is something on here somewhere where it is suggested to drive in figure eights after completed.Oh and make the bead about 1/8 to 1/4 of an inch,better to be a lil thick than not enough.Also make sure you scrape both the diff cover and surface of the diff,spray brake cleaner or similar on a rag and wipe the surfaces down before applying the RTV silicone.Make sure you follow the directions on the silicone for curing time.Also when you re-assemble try to get the cover in the right place so you don't have to move it around and screw your bead up.That's all i can think of for now.
Hope this helps,
Kevin
Hope this helps,
Kevin
Masonball it stopped almost immediately.Mine wasn't grinding though,it had a shudder on take off.I just looked at your other post and you have a 2wheel drive correct?You have to figure out where the noise is coming from
If it is coming from the front i would guess wheel bearings.How many miles on your truck?Have you ever re-packed the bearings w/grease?
Most of the shudder should go away right away - mine did , but it also smoothed out considerably more within the next fifty miles. I've heard 75 mles before it completly goes away in some cases..
BTW - Permatex high heat "Black" RTV sealant was all I used and I didn't give it much more than an hour of cure time and had NO leaks.
Good Luck
Good Luck
Good Luck
Good Luck
