Pinion bearing change
on
It takes a press to remove/install those bearings, and if the gear pattern isn't right (it probably won't be), the gears will have to be set up using a dial indicator. It's not a job for a shadetree mechanic. Click my signature link & look thru the 8.8" Axle album, and read this page.
If you ONLY replace the outer (front) pinion bearing, crush sleeve, & seal, you can do that. But you'll still need an inch-pound torque wrench to set the preload.
on
I agree with Steve. It takes a little know-how and some special tools and equipment, especially with the pinion bearing preload, to set up properly. Don't get it set right, and at best you'll get a little bearing/gear noise. At worst, the bearings will self destruct, weld themselves to the pinion gear and put you in a world of hurt.
